Hey all - I'm hoping someone can quickly answer this question for me. I am installing (as we speak) an F90BT in my '03 Infiniti G35 sedan, along with the Pioneer GEX-P10HD tuner and the Pioneer GEX-P920XM tuner.
While getting them set up in the vehicle, it says in the HD radio tuner's installation instructions to connect BOTH it AND the head unit to the vehicle's antenna. The HD radio tuner had an antenna included that you plug the male end into it and have a female end open.
The Head unit ALSO has a female input to insert the antenna cable. I puerchased the appropriate Nissan antenna splitter, which connects to the car and has one femaland one male cable on it. If I connect the male end into the head unit, it leaves me with just a female cable open and the female end of the HD radio antenna as well.
Do I need to purchase something else to connect these two cables: like a male-male antenna connector, or do I just need one or the other (HD tuner OR head unit( antenna cable connected?
I would REALLY appreciate a quick response if anyone can answer this for me!
For what it's worth, the installation instructions for the F90BT showed only that the HD tuner piggy-backed the XM tuner, not that it needed a separate antenna connection.
Cheers,
Kevin
