Hey Guys
I recently purchased a AVIC-F900BT and installed it into an Infiniti G35 w/ Bose. I used the metra 7551 wiring harness to keep the factory Bose amp. http://www.metraonline.com/products.aspx?s=7551 and the CD-IU230V ipod cable.
Upon wiring everything I tested the radio and it worked, sound is coming from all speakers but very low. When maxing out the volume on the f900bt, it isn't very loud, I cant even hear anything until I raise it to at least 45.
When using the IPOD connection, nothing is heard at all. Where could I have gone wrong? I didn't use the speaker wires, but used the pig tales(to retain the amp). If the amp wasn't powered then I wouldn't be getting anything out of the speakers at all right?
Also, does the f900bt come with a trim plate? The F900BT doesn't properly fit w/ the JDM Double Din kit, there's a bit of a gap.
