Night mode for map stopped working.
By RoyEP3 · Nov 01, 2008in Problems/Troubleshooting💬 11 posts👁️ 1,373 views
Posted Nov 01, 2008 · 04:52 UTC#1
I just discovered that holding the "V" button on my Z2 turns off the display!
So I don't know if this is connected with my issue or not, but I was pressing the V button to turn on/off my display, when suddenly I realize my map would no longer switch to night mode when I turn my headlights on.
I checked the map settings to make sure it's set for "automatic" and not "day" and it is still set to automatic.
So how do I get my map to flip to night mode again? I'm thinking about restoring hardware settings, but does doing that reset all my phone/address book?
Posted Nov 03, 2008 · 00:25 UTC#2
You should check your ILLUM wire's connection. I bet it came off/loose.
Posted Nov 03, 2008 · 06:06 UTC#3
Thanks for the suggestion. I'll try that as soon as I have an answer to the second question.
"I'm thinking about restoring hardware settings, but does doing that reset all my phone/address book?"
Posted Nov 05, 2008 · 19:27 UTC#4
anyone??
Posted Nov 05, 2008 · 22:11 UTC#5
Try the reset. But like 517244458_s.jpg said,
the ILL wire probably came loose behind your unit. Its a tons of wires back there and you never know.
Posted Nov 05, 2008 · 22:23 UTC#6
Yes, but will the reset delete my phone/address book and hard drive?
Posted Nov 05, 2008 · 22:29 UTC#7
No. And it won't fix your problem either.
Posted Nov 11, 2008 · 17:23 UTC#8
If you havn't had the time to check the illum connection, you might want to try this first.
Change the setting from 'automatic' to 'day'. Then, turn on your headlights. If the unit does not dim, then check the dim level. If the dim level is set to low with the headlights 'on' and the unit still does not dim - there is an open circuit to the illum connection.
'c'
Posted Nov 11, 2008 · 19:00 UTC#9
You can check if the wire is properly connected without pulling the unit by checking in the harware menu. You should see the illumination input toggle when you switch the lights on or off ....
Posted Nov 12, 2008 · 00:33 UTC#10
what if you have drls?...im having the same problem
Posted Nov 12, 2008 · 22:03 UTC#11
Thanks for that. I checked the hardware settings connection and illumination says "off" regardless of headlights on or off.
