outatime said:
Hi again
OK just doing some rewiring and I am still having problems with the PNR1 Sirius unit, I just made the PNR1 plug direct into the Z1 without any other units running through it and its still doing the same thing, I also tried 2 different cables to the z1 from the PNR1.
Basicly what happens is I turn the z1 on and onto Siruis and get no sound at all, then after a few mins of waiting I get a crackle, then I hear a distorted sirius, then after about 10mins of distortion it goes to normal sirius audio on whatever channel I choose to listen too, if I turn the car off and leave it for 10mins I have to do the same thing all over again.
Maybe a bad sirius box maybe, can't see I have wired it in wrong, everything is as normal, and the ipod box works fine through it so I am little confused at the moment to what it could be!!
Anyone any ideas?
Thanks as always
Stuart
Well, it's either a bad sirius box or bad antenna placement. Is your antenna on the top of the car? Is it 6 inches away from a window or whatever they recommend for the install? If the antenna is in the center of your roof (just run the wire out though a window for now) and you still get that, I would assume it's a bad sirius box. You could call sirius they usually answer tech support calls. But make sure you are out in a field (nothing over you) and your antenna is on the roof (nothing over it) and in the middle (away from a window or whatever). And if it's still doing it, I would bet it's a bad box.
