I need to know if anyone knows where the Vehicle Speed Sensor Wire and Reverse wire are on a 2005 F350. Planning on installing my AVIC-D3 tonight and thought I would see if anyone here knows. Thanks
VSS and Reverse wire for D3 in a 2005 F350?
what's the general way to determine this information for any vehicle anyway, consult its technical manual which doesn't usually come with the car?
Well got it all put in. My Factory radio harness on my truck had a grey wire with black stripe just like the one listed in another post I read. Once I got to looking at it...I noticed that wire''s location on the factory harness plugged into a spot with a pink wire on the Scosche Wiring Harness I ordered. And the Vehicle Speed Sensor wire on the AVIC-D3 is pink. So I looked it up and thats the one it needed to be hooked to. So the pink wire from the radio connects to the pink wire on the Aftermarket harness. Then when you plug the harness to the factory harness its good to go.
If anyone needed the harness number its a Scosche FD23B
http://cgi.ebay.com/ws/eBayISAPI.dl.....otohosting
