Failed application error?
By CatchMeIfYouCan631 · Nov 02, 2008in Problems/Troubleshooting💬 3 posts👁️ 863 views
Posted Nov 02, 2008 · 08:57 UTC#1
OK, basically what happened was I forgot my lighter at home while I was out, so I turned my car on quick to use the cigarette lighter, then turned it off. The avic was still booting up. Later on when I got into my car to go home, the splash screen came up with an error that read something like "The application failed to run during the previous start up. Would you like to restore back to default which will erase POI's, Track Info, (etc)" and a yes and no option. I clicked no and the unit froze. Instead of resetting it since I couldn't find my stylus, I pulled over and turned the car off/on, and now it works fine. It was just a random error message, but has anyone else ever seen this?
Edited to add, I haven't updated my unit yet, nor done any new hacks. Only Stephanie's Data.zip from a while back and a custom theme.
Posted Nov 02, 2008 · 16:32 UTC#2
I've also seen this message after quickly starting and stopping my car. It worked normally after clicking "no".
At first I thought it had something to do with my mods, but it just seems to be some kind of failsafe system. Nothing to worry about.
Posted Nov 02, 2008 · 17:48 UTC#3
OK good as long as its not a big deal. Thank you :D
