Update wont start ?
By norcalmike · Nov 02, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,132 views
Posted Nov 02, 2008 · 17:38 UTC#1
I cant seem to get the update to start, I know its probably something simple. I followed Pioneers instructions and downloaded and decompressed the files then thansferred them to a Fat 32 formatted Sandisk 2 gb SD card. But when I put it in the unit just starts up and no update. Any ideas anyone? Something simple I am over looking? LOL
Posted Nov 02, 2008 · 17:40 UTC#2
Make sure you have the right update.. the older 1.91 or whatever it was called is still available on their website and could be easily confused.
Make sure that there are no other files than what you uncompressed from the download.
Posted Nov 02, 2008 · 17:56 UTC#3
Couple things to try:
1. Re-format your SD card using the "default allocation size" then copy these files again.
2. Close your car door if it was open, depending on how your car and unit was installed.
Posted Nov 03, 2008 · 04:00 UTC#4
I tried everything listed above and have the right update. I even tried downloading it and decompressing it on a different computer. My F90BT is on 1.001700 so it should take the update. I'm going to get another SD card tomorrow and try it. Maybe it doesn't like the one I have.
Posted Nov 04, 2008 · 21:01 UTC#5
Make sure that the update files are on the TOP LEVEL of your SD card. when you open SD card, you should see LPUE080, TTS, CK5000_330_RLS.bin, flash_p4_lwp.bin and rtl_115200_8192_p4.bin and nothing else.
if you have a folder called "Update" (for example) and all of the update files are inside of that folder that is incorrect.
Posted Nov 05, 2008 · 03:51 UTC#6
Got mine to update tonight. I had to disconnnect the IP Bus for the Sirius tuner. Then it worked fine. The instructions said to remove any USB devices or ipods before the update but didn't mention the IP Bus unit. Maybe that is a form of USB ? Any way it worked
Thanks for all the suggestions
