Bluetooth acting weird?
By T0Mlol · Nov 03, 2008in Problems/Troubleshooting💬 24 posts👁️ 3,811 views
Posted Nov 03, 2008 · 21:20 UTC#1
I THINK ever since updating to 2.0 and updating the bluetooth, my calls have been acting up. Everytime someone calls me, It rings and when I answer it, no sound out of the speakers. They can't hear me, I can't hear them but the called was answered cause the time on the phone of the phone call is counting. If I call out, SOMETIMES it works, sometimes again, just quiet.
What is going on and is anyone getting this too? I'm pretty sure this happened after the update but I don't remember as I don't use the bluetooth THAT much.
Posted Nov 03, 2008 · 23:17 UTC#2
dito!
Posted Nov 04, 2008 · 14:04 UTC#3
Does anyone know how to get the previous BT firmware? Prior to 3.3.
Posted Nov 05, 2008 · 22:20 UTC#4
I am having this same exact problem. It is driving me up the wall as bluetooth was one of the main reasons I purchased this unit. Please, does anyone know of a cause or possible solution? By the way, I am using a F90BT with the latest updates and using an Iphone 2G. If I call out I don't have any problems. But if I receive a call and hit answer, the call acts as though it is active but no sound can be heard on either end.
Posted Nov 05, 2008 · 22:58 UTC#5
Honestly, I think having the pre 3.3 version Bluetooth firmware would fix it all. Assuming the unit will let you downgrade. I'll try emailing pioneer.
Posted Nov 05, 2008 · 23:32 UTC#6
Thanks for checking into this irkgreen. Please let us know your results. I tried pairing a friend's phone with the F90BT to see if it did the same thing and it seemed to work fine with his phone. I hope it is not an iphone specific issue with the new update. So they fix the blackberry issue..only to mess up the with the iphones..great. I am gonna try restoring my iphone and see if that makes any difference.
Posted Nov 06, 2008 · 00:35 UTC#7
Yes, after the 2.0 update, my bluetooth has been very buggy. It's hit & miss when the bluetooth feature works. Same type of symptoms: upon receiving a call, nothing can be heard on either end. It will then take sometimes a minute or two for the audio source to return back to sound.
EXTREMELY ANNOYING!!!!! Pioneer, please fix this important feature!
Posted Nov 06, 2008 · 01:35 UTC#8
have you guys tried listening if the sound is going through your phone? that is what is happening to me. sometimes it works fine other times i can initiate calls on my phone (lg 8550 chocolate) but the incoming and outgoing sound go through the phone.
Posted Nov 06, 2008 · 02:11 UTC#9
After restoring my iphone and resetting my Avic it seems not to be freezing up and not transfering the voice into my car as it was doing before. However, when I dial a contact's number it shows it as the dialing the contact with their name. When they call me, no name shows up but just their number. Is there anyway to fix this? It appears that the iPhone saves contact numbers with parenthesis and dashes, while the avic displays incoming calls as strictly numbers...I am not sure if this is contributing.
Posted Nov 06, 2008 · 04:00 UTC#10
Figured out the contact names not showing up on incoming calls. Just use SQLite to remove all the parenthesis and dashes from the numbers.
Posted Nov 07, 2008 · 04:23 UTC#11
I have not had this unit installed with the newest bt update. have anyone else besides who mentioned it already had this specific problem of bt sound not coming through the speakers before the update? if not im going to hunt down the previous bt software and try to install that. hopefully it will let me because i believe it checks if the current version is newer than the one you are trying to install (unless that's just for the firmware). has anyone tried this yet? i don't think there would be an issue running the older bt software with the 2.0 firmware but who knows.
when the last fw update was released, was there a bt update with it as well or was it just the firmware? ill search in the meantime.
Posted Nov 07, 2008 · 15:05 UTC#13
i have a blackberry, though a lot of the issues have been fixed regarding connectivity, i'm also experiencing similar problems as you folks with the audio...i can hear callers, but they can't hear me, it happnes out of the blue, randomly, don't think its a hardware issue, though i managed to pull the unit out to check microfone connection in the back it looked fine, the minute i unplugged the mic and plugged it back in, it worked again! so not sure what the issue is now...i can't b doing that...i'm starting to think this unit is not worth it again... :(
Posted Nov 07, 2008 · 15:34 UTC#14
great find!
Posted Nov 07, 2008 · 16:09 UTC#15
BTW BT version 2.9 works great! No complaints.
Posted Nov 07, 2008 · 17:00 UTC#16
good to hear. i am going to try it when i home. good to hear they didn't prevent you from downgrading. thanks for reporting back!
my guess is that most of the bluetooth fixes were for the blackberry on this.
Posted Nov 07, 2008 · 23:55 UTC#17
the downgrade didn't work for me. i wasn't expecting too much since i never have tested with the old version anyway. i wonder if this is a phone compatibility issue, a phone issue, or an avic issue. has anyone else tried downgrading and did it work?
Posted Nov 08, 2008 · 01:20 UTC#18
What o/s is on your phone todx? Perhaps you could get something similar to jetware to help mediate the BT communication. You shouldnt have to, but it sure is worth looking into.
Posted Nov 08, 2008 · 03:24 UTC#19
this isnt a fix, just a bloody patch... wtf... Pioneer needs to get their arse in gear and fix these ridiculous issues... they used to be my favorite company... day by day as I use this unit i realize what kind of shit they released.
Posted Nov 08, 2008 · 23:12 UTC#20
i don't have a smartphone so i don't think there is any type of add on i could add, at least that i know of yet.
Posted Nov 09, 2008 · 00:02 UTC#21
didn't I warn you already on nissanclub? Pioneer didn't make the bluetooth in the Avic's.. its third partied from Parrot using the CK5000 module. Parrot used to be a good name, but this is really a disappointment.
Posted Nov 09, 2008 · 00:20 UTC#22
Yes, there are a few flaws... but it might have a future, every series has their issues at first... the problem is they pre released it and were just looking for $... fuck that if I wanted to get a corporate company that doesnt give a fuck about quality and client id get Sony...
Posted Nov 13, 2008 · 05:03 UTC#23
if anyone cares i was able to make repeated successful calls through my speakers using a friends phone (a windows ce based phone). It seems like after my first call is when sound stops coming through the unit and into my phone. i called lg about it and they said of course call pioneer about it. ill try pioneer again but ill prob be looking to just get a different phone somehow so i can use this thing like its supposed to.
Posted Nov 18, 2008 · 02:51 UTC#24
Just wanted to toss out that the 2.9 fix worked for me. After the 3.3 update both my inbound and outbound calls would stay connected (I could tell by watching the phone itself), but neither party could hear each other making the bluetooth funtionality basically worthless.
I downgraded to the Bluetooth 2.9 version tonight...resynced the phone to the F90, redid the contacts...problem solved.
http://ds1.sfo.downloadtech.net/cn1010/ ... Ver2.9.zip
My phone is a Motorola Maxx VE.
