F90bt VR control button doesnt respond
By gatorpa · Nov 06, 2008in Problems/Troubleshooting💬 18 posts👁️ 3,066 views
Posted Nov 06, 2008 · 01:07 UTC#1
Anyone having an issue with the VR control button not responding after the update?
I turned the catalog mode off after realizing that it was the cause of resetting my itouch and the system after a few minutes.
Now I find that when I want to make a phone call or switch av sources, the button control does not work. No menu comes up. The only thing I have done so far was reset factory settings, but no hard reset or reinstall of v2.0.
And yes skicrave I have searched for the answer :wink: .......so any help appreciated.
Posted Nov 06, 2008 · 01:21 UTC#2
Having the exact same issue. Just installed my system and hadn't even tried VR before I updated to 2.0. But it's the only thing that does not seem to work. Can mute the system and change stations fine, but no Voice Command.
Posted Nov 06, 2008 · 02:18 UTC#3
Exactly, glad to know I'm not alone...take it you havent found anything on the forum either?
Posted Nov 06, 2008 · 02:36 UTC#4
My reputation proceeds me! ;)
What screen are you on when you try to initiate voice control? Have you tried it on other screens?
Posted Nov 06, 2008 · 02:37 UTC#5
just to be sure, are you guys trying the VR when the map is showing? if you try on your av screen or elsewhere it wont work for me. i think i remember reading in the manual somewhere that VR only works in maps but i could be mistaken.
Posted Nov 06, 2008 · 02:41 UTC#6
Nope, searched around and even posted a similar thread about 10mins after yours which I then deleted when I saw what you had said. I was gonna pull the unit out and quadruple check that the mic was in the right port, but since yours worked previously and now doesn't it must be some type of firmware issue.
Posted Nov 06, 2008 · 02:42 UTC#7
Tried it in map screen, ipod screen, and av selection screen. No dice for all.
Posted Nov 06, 2008 · 02:52 UTC#8
Checked manual again and the "multi control" knob should initiate with maps and AV source. I'll try tomorrow on both, good suggestion
Also anyone having to reset their time zone EVERY time they go to maps?
Posted Nov 06, 2008 · 03:57 UTC#9
yes i have the same problem as well. looks like theres a bug in the update. it works for me after i go to my contacts screen and call by manually selecting a contact and calling. then after that my VR works. and it used to work on the map screen and the av screen but not anymore until i place a call manually.
Posted Nov 08, 2008 · 02:32 UTC#10
Any luck gatorpa?
Posted Nov 08, 2008 · 03:57 UTC#11
I'm having the same issue as well on my F900. No VR from the click wheel.
Posted Nov 08, 2008 · 14:03 UTC#12
I am assuming you guys hit the little reset button by the eject button? Also you could try reinstalling the update from scratch.
Is there any sort of back to factory reset, one shot one kill? I saw there is one for navigation settings only, and then the reset button ( the little pin hole button) for a reset of the AV controls, I noticed though neither of those however change your splash screen back to default, and none end up asking for language settings again, so its not a complete factory reset.
Does it exist or no? If it does, perhaps try that after the update.
Posted Nov 09, 2008 · 16:13 UTC#13
Yeah, I can't get it to update again because the v2.0 is already applied. And I haven't been able to reset it at all. Just weird that it's happening to some systems and not others.
Posted Nov 09, 2008 · 20:51 UTC#14
I had the same VR problem after the 2.0 upgrade. I logged a case with Pioneer and they said they'd get back to me. Ofcourse they hadn't.
Anyways the unit is completely dead now so I'm SOL and I'll probably have to get this thing replaced.
Arg....
Posted Nov 09, 2008 · 21:54 UTC#15
not trying to make anyone with a problem mad but just letting everyone know that it is a limited problem because my f90bt with 2.0 the vr works fine.
When in ipod mode or map mode and I press up on the wheel the vr comes right up and beeps for input;
Posted Nov 10, 2008 · 01:41 UTC#16
Thanks lasrx. How long ago did you log it? I think I'll do the same tomorrow.
Yea blackh, so far there doesn't appear to be any reason why some work and others don't. Something must be causing it though.
Posted Nov 10, 2008 · 03:00 UTC#17
And now that I have posted this, VR has come back to life. (this unit acts like my wife), but I love it anyway........
Sorry cant explain the quirck, but I'm sure there will be more
Posted Nov 11, 2008 · 04:30 UTC#18
Well, I got it working. In language I selected English again, it rebooted, and the VR worked.
Who knows why?
