Is there a way to calibrate the screen on a Z1?
Every time I touch a button on thee screen, the button next to it is what activates.
Don't you have the manual? Anyway, use a stylus to do this (my installer tossed it so I used my PDA stylus, all the same):
1 Press the V button.
The Picture Adjust screen appears.
2 Press and hold the V button for two seconds
or more.
The 4-point touch panel adjustment screen
appears.
3 Touch and hold each of the arrows on the
four corners of the screen with the touch
panel adjustment pen.
Hold the pen on the arrow until each one of
the four arrows turns red.
4 Press the V button.
The adjusted position data is saved.
❒ Do not turn off the engine while saving the
adjusted position data.
❒ Press the MAP button to complete the 4-
point adjustment.
5 Press the V button.
The 16-point touch panel adjustment screen
appears.
6 Gently touch the center of the + mark displayed
on the screen with the touch panel
adjustment pen.
After you touch all marks, the adjusted position
data is saved.
❒ Press the V button to return to the previous
adjustment position.
❒ To cancel the adjustment, press the MAP
button.
7 Press the MAP button.
The adjustment is complete.
❒ If touch panel adjustment cannot be performed
properly, consult your local Pioneer
dealer.
Thanks for the info!
