touch screen dead when remote starter used
By oldschool · Nov 07, 2008in Problems/Troubleshooting💬 3 posts👁️ 835 views
Posted Nov 07, 2008 · 00:34 UTC#1
Hopefully someone can help. My partner at work and I both have the same problem with avic-F90BT's. His is in a toyota and mine is in a 2005 explorer. Same alarm ( audiovox aps-997a). Never had a problem with the alarm (I've used about 10 over the past 2 years). anyway when you remote start the car, the radio turns on fine and plays but the touch panel is dead. All pysical button work but nothing on the display. If you trun the car off and restart then its fine. This only happens when you first start the car with the remote. Thanks
Posted Nov 07, 2008 · 01:23 UTC#2
Mine has different problem with remote starter.
It will not connect to msn direct when remote started.
But my screen works fine.
Posted Nov 07, 2008 · 03:44 UTC#3
Check voltage going to the radio during remote start. Also if the radio goes on and off during the remote start process.
