iPod Cable, hardware bypass and VSS questions.
By drewjewbe · Nov 07, 2008in General💬 2 posts👁️ 736 views
Posted Nov 07, 2008 · 14:08 UTC#1
Hi everyone, just wanted to say what a great forum this is. Just purchased a F700BT and am having it installed on Tuesday. I have a few quick questions for you.
Do you know if you can hook up an iPod/iPhone through a standard USB cable or if you have to use the special Pioneer one (CD-IU230V).
Also I did the hardware bypass (moved the mute wire). All I have to do know is ground the mute wire and the parking brake wire correct? No software modification necessary?
One last question, I read in the manual that I do NOT have to connect the speedometer sensor wire for the F700BT, is this the case? Do I lose any functionality if I don't connect this wire.
Thanks for your help in advance!
Posted Nov 07, 2008 · 16:10 UTC#2
Welcome to the site!
Search, search search! All of these questions have been covered in great detail previously, and I believe that all of them are in the FAQ's at the top of each forum.
You must use the Pioneer or Apple Composite A/V cables to get audio/video AND control of the iPod.
The parking break and relocated mute wires must be grounded.
The F700 doesn't have a VSS wire, so it's not possible to connect it.
