I am trying to put the wires together but I'm not sure how to sucessfully accomplish this. I attached a pic with one of my main concerns. Basically is just matched them and ground 2 here and 1 in Connector 2, right?
1. I have a ground in my harness, should I use that one? Or should I ground each one individually or tap the one in the AVIC harness with the car harness and ground that longer cable.
2. The green (parking brake ground) should be grounded on it's own or can be tapped into so I can ground 3 things using 1 wire.
Any other suggestions (or help) would be highly appreciate . Thanks
Posted Sep 16, 2006 · 03:49 UTC#1
