Testmode - Can I do.....
By lsdb23 · Nov 08, 2008in Hacks/Mods💬 5 posts👁️ 1,359 views
Posted Nov 08, 2008 · 04:08 UTC#1
Guys,
My HD RADIO screen is locked up. Can I use TESTMODE to reset the whole unit back to original settings like I just took it out of the box??
The HD RADIO screen is locked up. It has no signal-has no audio-can't change Bands. It was working before I started trying to get MSN Direct to work. I have a Y spliiter for the Antenna and nothing on the HD RADIO screen works. I even tried to remove the y splitter but nothing works.
So can I use a default Data.zip to restore the unit to original settings and see if that helps with the screen lockup on the HD Screen??
Thanks for the help.
Posted Nov 08, 2008 · 04:19 UTC#2
there is a reset button on the head unit and on the hd radio piece.. try them
Posted Nov 08, 2008 · 04:30 UTC#3
The reset button doesn't do anything...
Is there a reset button on the Pioneer HD Radio unit??
Thanks.
Posted Nov 08, 2008 · 23:45 UTC#4
No there is no reset button... I am actually having the same problem. The odd thing is my XM works which is connected thru the HD Radio unit.
Posted Nov 09, 2008 · 00:36 UTC#5
I think I found my problem. I think the MSN DIRECT and HD RADIO are fighting over signal strength from my stock car antenna due to the Y splitter I installed to get both to work. I got into the car today and the HD RADIO worked. I was like what!!! However I saw my signal strength of my MSN Direct was almost zero.
I'm going to try a FM Booster from Crutchfield and see if that helps.
XM works because it has its own antenna....
Hope that helps. I will post once I get the booster. I really would like to have both MSN DIRECT and HD RADIO. I would hate to have to unhook one or the other.
