I'm trying to do the hardware bypass with grounding the parking brake wire and relocating/grounding the mute wire.
In the picture I attached, you can see what I am trying to do. I've connected the power/speaker wires from the F700BT to the Toyota harness that I got from Crutchfield. As such, there's a splice between the FT700BT and the harness ground wires. I've (temporarily) connected the parking brake wire to that splice, and my understanding is that not only do I have to relocate the mute wire, which I did, but also ground it, so I was going to connect that to the splice area as well.
Don't worry -- if this is the way to do things, the permanent connection I'll make will be much neater.
1. Is this the right way of grounding the parking brake and mute wires?
2. What is this mute wire used for, anyway? The installation manual says, "Yellow/Black - If you use equipment with a mute function, connect that equipment to the Audio Mute lead. If not, keep the Audio Mute lead free of any connections." Ironically, it seems that if you install one of these F-series units, I can't think of any other equipment that I would install.
3. (I think I know the answer to this, but I want to see if I'm right.) The install instructions say to move the mute wire out of the way if it's not being used. Why does it have to be grounded for this hack?
