Modifications Made Easy
By lobelsteve · Nov 08, 2008in Hacks/Mods💬 21 posts👁️ 8,355 views
Posted Nov 08, 2008 · 23:19 UTC#1
It really is not complicated editing and adding files, but heck, I needed 5 hours of time to do the hardware bypass due to a bad system ground on the din chassis. Lots of wasted soldering....
EDIT 11/9/08 6AM: Before doing any of this, go to the FAQ and read how to back up your files to the SD card and make a copy of the backup on your PC. (A complete backup is available online for $10 via paypal :lol: )
Anyways, I wanted to make a simple solution for the beginner to get started with the mods I found most useful. Here are simple instructions and a link to a ZIP file containing an all in one for a few mods. The directions below are included in an MS Word file in the zip.
The file is here: http://www.box.net/shared/2iz59qsiom
1. Unzip the Common_hacks.zip file to a freshly formatted SD card.
2. Put SD into the AVIC and turn on the car.
3. Wait for WIN CE to boot and click the X on top right corner of screen
4. Double click My Device and open Storage Card folder
5. Highlight and copy DATA.zip (Edit/copy)
6. Click back to My Flash Disk/APL2/iGo
7. Delete DATA.zip
8. Paste the new DATA.zip
9. Go back to Storage Card folder and copy Branding.zip and paste in My Flash Disk/APL2/iGo
10. Exit to main screen
11. Turn off car and remove SD card.
12. On reboot it will be updated. You can then click on System Settings through Avic and upload pics from the pictures folder on the SD card as your background. I included a few pics.
Files included:
Testmode folder
MiTACAP folder
DATA.zip (already modified)
Branding.zip
Pictures folder
Mods include:
Software bypass set to 256 kph (159 mph)
Compass button route delete function
Voice guidance mute button
Branded Icons for AVIC
Credit to BorisM and VBLUE42.
http://www.avic411.com/forum/viewtopic.php?t=18428
Copy Branding.zip to: Myflash/apl2/igo
Upon reboot you will have all new POI icons. Most will already be linked to their perspective categories but some will have to be selected manually the first time through the MANAGE POI screen on the unit. The only categories not covered in this file are fast food restaurants but I suspect that’s because there is no such option under the restaurants category on the F series.
Posted Nov 08, 2008 · 23:40 UTC#2
Thanks! Though, I think we could have done without your 'Pictures' folder...
Posted Nov 09, 2008 · 00:01 UTC#3
Cool, thanks for all the work! I assume this is v2.0?
Posted Nov 09, 2008 · 00:46 UTC#4
Yes, 2.0
And to prev post: I just put the folder there because when I wanted to move some over the first time, I did not have the folder named pictures, I just copied them to the Data folder and was like, where are they.
It would be easy to copy them over to the AVIC, but that would entail making the AVIC then find them. Too much work.
Posted Nov 09, 2008 · 00:47 UTC#5
No, I mean.. the contents of the Pictures folder. lol ;)
Posted Nov 09, 2008 · 01:49 UTC#6
GOOD JOB BRO! ALOT OF PEOPLE HAVE A HARD TIME SEARCHING FOR THESE HACKS IN THE FORUM. THANKS YOU
Posted Nov 09, 2008 · 02:34 UTC#7
PM the adim and see if you can get this into the a sticky somewhere.
Though you've done a lot of work and a lot of thought already, maybe top this off with a pic of the finished product. Kinda showing where the voice mute button will be. And reiterating the compass button will double for the route deletion button.
I saw the pics also, needs blood! :lol:
Posted Nov 09, 2008 · 02:48 UTC#8
You might want to append your directions to state "backup your existing data.zip" and "I do not provide any support or assume any liability USE AT YOUR OWN RISK"
8)
Posted Nov 09, 2008 · 03:13 UTC#9
8)
x2 Valiant effort and appreciated, but to everyone using this ALWAYS use caution modding if you are unsure of what you are doing!
Posted Nov 09, 2008 · 18:35 UTC#10
i do it this way...
i copy the files i want to modify out the data.zip and modify them on my computer. then i copy only those files back head unit via a sd card. you have to create the correct folder structure you find in the data.zip file.
so i don't modify or change any thing on the head unit but add my modified files. so i can go back very simple by just delete the added file. no need to zip or unzip etc. and if you make a error in one of the added file it's easy to correct.
Posted Nov 09, 2008 · 20:07 UTC#11
I changed everything I wanted to via the 2.0 update data.zip and let the head unit work its magic with updating the unit to 2.0, while also adding a few mods.
Posted Nov 09, 2008 · 21:46 UTC#12
I could not find the information in FAQ on how to back up the existing data or information online for PayPal. Any direct links? Or can you please provide this information?
Thanks!!
Posted Nov 11, 2008 · 01:05 UTC#13
The complete backup was a joke, its available on here from searching.
THe backup is as easy as going into testmode and copying and pasting the My flash disk to an SD card, then copying it to a folder on your PC.
Posted Nov 16, 2008 · 19:55 UTC#14
On what models does the mod work? :?:
Posted Nov 17, 2008 · 11:55 UTC#15
Isn't the original Pioneer data.zip in the firmware update? I don't see a need to keep backing this up unless you want to save a version with each modification.
Am I wrong here?
Posted Nov 24, 2008 · 14:10 UTC#16
I followed the instructions to a T and go the buttons to show up (mute and compass) but they don't do anything. Neither of them.
Any ideas? (v.2 w/ F90BT)
Posted Nov 28, 2008 · 02:42 UTC#17
I have copied the data file several times and haven't seen any results. I first tried copying the file into the appropriate folder. After that didn't work, I dragged and dropped the DATA file into the appropriate folder. Still no luck. Any ideas? My main concern is to get the software bypass working. I figured the bypass was included in the data file.
Posted Dec 05, 2008 · 18:11 UTC#18
this post should be stickyed. it was simple and informative. although i did end up deleteing some of the included pictures lol...thanks for doing this though. worked like a charm. 8)
Posted Dec 07, 2008 · 21:02 UTC#19
I'm also not getting the software bypass to work here. I mostly want it for using the nav with a passenger to manipulate it.
For the folks having trouble with the buttons not working, you may need to recalibrate the screen. I did that and mine now works (just not the bypass).
joneSi
Posted Dec 07, 2008 · 21:31 UTC#20
This worked like a charm. I couldn't find data.zip that easily on the nav system. Once I found that file, it was a breeze.
Posted Dec 13, 2009 · 20:16 UTC#21
the file is no longer on boxnet can someone repost the file.
thanks :?
