Hooked up Sirius - No Audio
By Ken Wolkens · Nov 09, 2008in Problems/Troubleshooting💬 3 posts👁️ 743 views
Posted Nov 09, 2008 · 23:04 UTC#1
I did the original install on my AVIC 700 and everything worked fine...GPS, Rear Camera, Video In from Rear DVD Player, AM/FM, CD Player....It all works great.
The easiest part of this install was the Sirius. Plugged in the pioneer controller ran power and ground to it, plugged in the sirius to that and ran the antenna. I've got a signal, can see the channels, and received the update on the radio after I activated it. Basicallly everything but sound.
I hit the reset button on the Avic, still no sound from sirius. What did I miss?
Posted Nov 09, 2008 · 23:51 UTC#2
Make sure you have th IP-bus cable in the right port on the Sirius. It should be in the "IP-Bus Out" port. Plugging it into IP Bus In will usually result in full functionality minus audio.
Posted Nov 10, 2008 · 00:31 UTC#3
That was it. Thanks for the insight. :)
Ken
