This is not the appropriate disc
By nailerpa · Nov 09, 2008in Problems/Troubleshooting💬 5 posts👁️ 2,466 views
Posted Nov 09, 2008 · 23:15 UTC#1
Hello everyone,
I bought a set of the 2007 DVD navigation disks for the AVIC-N3 (CNDV-70MTP ) off of eBay. When I put them into my DVD player, the Pioneer splash screen comes up. However, when I go to the navigation screen, I get the following error message: "This is not the appropriate disc. Please insert the appropriate disc" Anyone have any ideas as to what the problem might be and how to fix it? Thanks!
Posted Nov 11, 2008 · 03:18 UTC#2
What disks did you have prior to using it? This message comes up when you put an older version into the unit once it's been updated. Sounds like you've already used the 80 series and tried to go back. I had the 60 series (purple) then I went to the 70 series that I got off ebay. Bootlegged version. Worked great for 3 months then stopped. I had to get into the service menu and reset the unit to use my old disk. Once you've upgrade you can only use the same series or go up higher, you can't go back without resetting
Posted Nov 11, 2008 · 03:22 UTC#3
Thanks for the reply! I had the 60 series (purple) discs...from 2006. The "new" discs I have say they are from 2007 (on the Pioneer splash screen). For now, I'm using my older discs again. Any other ideas?
Posted Dec 04, 2008 · 19:04 UTC#4
Got2003GTP
How did you reset your unit to go back to an older version??
I know it is in the service menu and you need a remote but can you tell me what you selected in the service menu??
Thanks in advance,
Randy
