F900BT - Firmware 2.0 Problem - Black Screen on Boot
By THalladay · Nov 10, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,210 views
Posted Nov 10, 2008 · 18:58 UTC#1
So I've installed the new firmware per the instructions. When my unit rebooted after successfully installing, it flashed the pioneer screen, and then it all went black.
Per the instructions, I have tried all the variations of resetting the unit. Holding the reset button 5+ seconds, holding reset button & eject button 5+ secs, holding the eject button.... etc. etc.
Here's the weird part: When my unit boots, and then goes black, after about 20 seconds or so, I can press the Map button, which takes me to the disclaimer, and then i can do everything with my system.
Also weird: if I do the above, and play the radio, the next time I boot, the screen is and stays black, but the music will play. Black screen doesn't go away until I do the above.
Has anyone had this problem? I see almost nothing but success in the other 2.0 threads....
Posted Nov 12, 2008 · 21:58 UTC#2
need to update the bluetooth , use the update firmware v.2, after that will ok.
Posted Nov 13, 2008 · 01:19 UTC#3
wtf... where did you pull that "answer" from?
thalladay, when you were updating it, were you driving or did you open the door?
Posted Nov 14, 2008 · 16:11 UTC#4
I have installed both the Firmware 2.0 AND the Bluetooth update 3.3...........
Nope, I was in my truck parked, no doors opened, in Accessory mode.
After playing with it some more, I have a hunch that I've messed it up by trying to play video files. It doesn't seem to like any of the MP4 / MPEG2 / WMV's that I've tried to play off my SD card. After trying to play various files, it gets less and less responsive, and now can't exit the black screen unless I hard reset the unit.....
Posted Feb 07, 2009 · 22:16 UTC#5
Did anyone else get this same problem since updating to the 2.0 firmware? I haven't sent it back to pioneer yet, it's been a lazy winter. But I still have the problem.
If I press the magic combo of map + menu 1 in 4 times I can get the screen to come back on and everything is normal (for the duration of the power being on in the car for that trip).
Very frustrating, and I don't see any similar experiences in the forums....
Posted Feb 07, 2009 · 22:30 UTC#6
Nevermind, was able to figure it out thanks to this thread:
http://avic411.com/forum/viewtopic.php?p=145146#145146
....ugh..... for 4 months I've been living with a crippled head unit
Since it happened when i updated the firmware, i always thought it was just the firmware that bricked it for me.
