F90BT+Inserted SD Card=SLOW!
By djsukebe · Nov 10, 2008in Problems/Troubleshooting💬 3 posts👁️ 777 views
Posted Nov 10, 2008 · 19:22 UTC#1
Hi All,
Did a quick search on the forums and found nothing on this. Has anyone run into a really slow/lagged system (delayed button responses, etc) after inserting an SD Card into a F90BT or any other model for that matter? I am using a 4GB Class 4 SDHC card formatted in FAT32. I also tried a basic 512MB SD Card formatted in FAT32 and got the same result. Any help would be greatly appreciated. Thanks
Edit: Did a little more searching and found that people are having this issue when attempting to play video from SD. My issue is right from the start, when you insert the card. I am raising this issue again as it seems there is no answer to the previous threads. Thanks
Posted Nov 10, 2008 · 19:40 UTC#2
If you put in an SD card with MP3s, do you still experience the same lag? Have you updated to 2.0?
Posted Nov 10, 2008 · 20:01 UTC#3
Sorry should have been more detailed. Yes 2.0 upgrade has been implemented. I have not tried MP3 only. Currently I just have videos on the card but will try MP3 only and see if that makes a difference.
