Problem 1
So I pulled the old Kenwood Unit (which was working great) and replaced it with an F90BT. I have the RCA's going to an ALPINE amp in rear. I connected the wiring harness and now I only hear full signal from the rear speakers! The fronts are tinny and sound like half signal (kindof like when you plug headphones in halfway.... no vocals, tinny instruments)
•I switched the front output to RCAs I know are working properly and the tinniness is still there. This proves the only thing possibly causing this is the wiring harness (all the pins look good) or the unit itself.
•I plug the front RCA's into the rear output and get full signal to the front speakers
Problem 2
I moved the yellow mute wire for bypass and grounded the black, yellow and light green wires to the wiring harness ground (same ground as the kenwood unit) I now have bad engine interference that gets more high pitched as I accelerate. At first I thought this must be ground so I redid the wiring but it didn't solve the problem.
•The interference is non existent if the car isn't running.
Problem 3
I purchased this unit from eBay and I know returning it is going to be a b***h. I'm hopeful I have hooked something up wrong or overlooked something.....
