VSS/Vehicle Speed Sensor wire Ford Escape Hybrid 2009 (Snyc)
By ash3x6 · Nov 11, 2008in Vehicle Specific Wiring💬 4 posts👁️ 3,359 views
Posted Nov 11, 2008 · 03:04 UTC#1
On the new Ford Escape2009 Hybrid which wire is the new VSS or Vehicle Speed Sensor wire behind the stereo. I opened it up and looked and its not the same as the -2008 and below. All help greatly appreciated, I just want to get a switch on there and be able to use my POI while driving. Thank You!
Ford Escape Hybrid 2009 w/ Microsoft Sync Navigation. Which wire on the back of the stereo is the VSS cable? I have seen the wiring for the 2008 model and it is different for the 2009. I even have the wiring diagrams for the three connectors going in to back of the navigation/audio unit but they do not clearly state which pin/cable is the VSS/Vehicle Speed Sensor. Below is the name of the 3 connectors and the circuit function for each pin.
C240A
AUDIO CONTROL MODULE (ACM)
Pin Circuit Gauge Circuit Function Qualifier
1 SBP39 (WH-RD) 16 FUSE - 39 OR CIRCUIT BREAKER
2 * * Not Used
3 DME07 (-) 20 CTRL MOD. - AUDIO # FRONT
4 * * Not Used
5 * * Not Used
6 * * Not Used
7 CME27 (YE-VT) 18 CTRL MOD. - AUDIO # ENABLE / CLIPPING
8 VME07 (WH) 18 CTRL MOD. - AUDIO # SPEAKER LEFT FRONT DOOR (WOOFER)
8 VME07 (WH) 22 CTRL MOD. - AUDIO # SPEAKER LEFT FRONT DOOR (WOOFER) AMPLIFIER
9 VME09 (WH-GN) 18 CTRL MOD. - AUDIO # SPEAKER LEFT REAR
9 VME09 (WH-GN) 22 CTRL MOD. - AUDIO # SPEAKER LEFT REAR AMPLIFIER
10 VME12 (BN-WH) 18 CTRL MOD. - AUDIO # SPEAKER RIGHT REAR
10 VME12 (BN-WH) 22 CTRL MOD. - AUDIO # SPEAKER RIGHT REAR AMPLIFIER
11 VME10 (WH-VT) 18 CTRL MOD. - AUDIO # SPEAKER RIGHT FRONT DOOR (WOOFER)
11 VME10 (WH-VT) 22 CTRL MOD. - AUDIO # SPEAKER RIGHT FRONT DOOR (WOOFER) AMPLIFIER
12 RME10 (WH-OG) 18 CTRL MOD. - AUDIO # SPEAKER RIGHT FRONT DOOR (WOOFER)
12 RME10 (WH-OG) 22 CTRL MOD. - AUDIO # SPEAKER RIGHT FRONT DOOR (WOOFER) AMPLIFIER
13 GD115 (BK-GY) 16 GROUND - CROSS CAR BEAM # 2ND STUD
13 GD115 (BK-GY) 18 GROUND - CROSS CAR BEAM # 2ND STUD AMPLIFIER
14 * * Not Used
15 CBP28 (GY-VT) 20 FUSE - 28 OR CIRCUIT BREAKER
16 RME24 (BU-WH) 22 CTRL MOD. - AUDIO # SWITCH REDUNDANT AUDIO
16 RME54 (WH-VT) 22 CTRL MOD. - AUDIO # SWITCH REDUNDANT AUDIO CDX6
17 VME54 (BU-OG) 22 SWITCH - REDUNDANT AUDIO
18 VME14 (GY-YE) 22 SWITCH - REDUNDANT AUDIO
19 RME24 (BU-WH) 22 CTRL MOD. - AUDIO # SWITCH REDUNDANT AUDIO
20 * * Not Used
21 RME07 (WH-BN) 18 CTRL MOD. - AUDIO # SPEAKER LEFT FRONT DOOR (WOOFER)
22 RME09 (BN-YE) 18 CTRL MOD. - AUDIO # SPEAKER LEFT REAR
22 RME09 (BN-YE) 22 CTRL MOD. - AUDIO # SPEAKER LEFT REAR AMPLIFIER
23 RME12 (BN-BU) 18 CTRL MOD. - AUDIO # SPEAKER RIGHT REAR
23 RME12 (BN-BU) 22 CTRL MOD. - AUDIO # SPEAKER RIGHT REAR AMPLIFIER
24 DME09 (-) 20 CTRL MOD. - AUDIO # REAR
C240B
1 VME52 (BU) 22 CTRL MOD. - AUDIO # APIM LEFT
1 VME41 (GN-OG) 22 CTRL MOD. - AUDIO # SATELLITE DIGITAL RADIO LEFT EARLY PRODUCTION
2 RME52 (GY-OG) 22 CTRL MOD. - AUDIO # APIM
2 RME41 (BU-BN) 22 CTRL MOD. - AUDIO # SATELLITE DIGITAL RADIO LEFT EARLY PRODUCTION
3 DME45 (NONE) 18 JACK - AUDIO # EXT. AUX IN
4 VMN14 (WH-VT) 22 CTRL MOD. - NAVIGATION # AUDIO OUT (MONO)
5 RMN14 (GY-BN) 22 CTRL MOD. - NAVIGATION # AUDIO OUT (MONO)
6 VME46 (BU-GN) 22 JACK - AUDIO # EXT. AUX IN RIGHT (+)
7 VME45 (BU) 22 JACK - AUDIO # EXT. AUX IN LEFT (+)
8 RME45 (YE-GN) 22 JACK - AUDIO # EXT. AUX IN LEFT (-)
9 VME53 (VT-GN) 22 CTRL MOD. - AUDIO # APIM
9 VME42 (VT-BN) 22 CTRL MOD. - AUDIO # SATELLITE DIGITAL RADIO RIGHT EARLY PRODUCTION
10 RME53 (BN-WH) 22 CTRL MOD. - AUDIO # APIM
10 RME42 (YE-BU) 22 CTRL MOD. - AUDIO # SATELLITE DIGITAL RADIO RIGHT EARLY PRODUCTION
11 VMN01 (BU-BN) 22 CTRL MOD. - NAVIGATION # MICROPHONE OUT
12 RMN01 (GN) 22 CTRL MOD. - NAVIGATION # MICROPHONE OUT
13 * * Not Used
14 RME46 (WH-GN) 22 CTRL MOD. - AUDIO # SATELLITE DIGITAL RADIO RIGHT
15 VDB06 (GY-OG) 20 CONNECTOR - DIAGNOSTIC # CAN BUS MEDIUM SPEED HIGH
16 VDB07 (VT-OG) 20 CONNECTOR - DIAGNOSTIC # CAN BUS MEDIUM SPEED LOW
C240C
1 VME22 (VT-GN) 20 CTRL MOD. - AUDIO # SUBWOOFER/AMPLIFIER AUDIO +
2 RME22 (GN-WH) 20 CTRL MOD. - AUDIO # SUBWOOFER/AMPLIFIER AUDIO -
3 DME22 (NONE) 20 CTRL MOD. - AUDIO # SUBWOOFER/AMPLIFIER AUDIO
4 SME23 (VT-RD) 20 CTRL MOD. - AUDIO # SUBWOOFER/AMPLIFIER ENABLE
5 * * Not Used
6 * * Not Used
7 * * Not Used
8 * * Not Used
Posted Nov 14, 2008 · 18:57 UTC#2
thats not going to work anyway. you need to bypass your unit. the speed sense has nothing to do with it
Posted Dec 06, 2008 · 17:01 UTC#4
The VSS wire is not the only way the avic knows the vehicle is in motion, it also detects speed thru the gps antenna. You need to do the bypass in order to operate everything while in motion. There are several forums on this site explaining how.
The short and sweet of it is: ground the ebrake wire (typically green), then move the mute wire (yellow/black) from it's factory location to the open location between two black wires in same plug, then ground it also. (these wires are on the avic f series, not the car). Now the avic won't care if the car is moving or not.
Hope this helps.
