OK. I've searched a bit but have not been able to find a clear, complete answer. Here's what I am looking for...... if a step by step is out there, please let me know..... I simply could not find it. Plenty on samples, and the JPG backgrounds, but not much on the loading side.
I have a Z1 (updated to a Z3 with a hard drive upgrade) that I would like to change the "Splash" or "Loading" graphics on. I want to get rid of the Pioneer opening screen and change it to something to give me the OEM feel of the unit in the car.
Here is what I have found out so far:
- Pixel Dimensions must be 500x240 for the images.
- The images must be in BMP format.
I am a pro photographer so I can use Photoshop in my sleep and this part is a cake walk.
I know there are two files I need to change.
CPYDEFAULT.BMP which "overlays the default background"
CPYCUSTOM.BMP which "overlays any custom background"
I dont know what that means exactly. On the first file... I thought this was the actual background for the loading....On the second, is it just the copyright and system info on a clear background? I assume that is what it means. ie. one is the background and the second is the overlay of the text.
So....... given that. I have a few more questions.
1. Do I need to change both images?
2. Since the files are BMP files, clear backgrounds are possible. Must I use that for both or the second? ....or is it straight up backgrounds of choice?
2. How do I load these using a CD with the HDD in the Z1/Z3? Can it even be done?
3. If I can transfer with a CD, must I create a specific directory to put the files in? ( I know that I must do this for general backgrounds I can use. )
4. If the only way to transfer is using the HD connected to a PC, what directory must I put the files into?
5. Again, if PC Connected is my only option, must I get the "unlocking S/W" I've read about in order to access the location?
