I was curious if anyone has screwed up on soldering r197? Is it possible to
take the unit apart and solder from the top? Thanks
I was curious if anyone has screwed up on soldering r197? Is it possible totake the unit apart and solder from the top? Thanks
If you're not good with soldering look into a circuitwriter pen, it will remove your doubt.
I wouldn't open the unit unnecessarily, unless you are trying to make a repair.
I have taken my n2 apart already. does anyone know if you can solder them back on from the inside. It's difficult to see where r197 makes the connection on the inside of the board. Anyone try this before? Thanks.
I really don't understand what you're getting at.
Did you melt off the contact points?
If you did, I believe the N1 bypass will work. It is the same exact board I think.
