Avic N1 question.
By dozug · Nov 12, 2008in General💬 6 posts👁️ 1,322 views
Posted Nov 12, 2008 · 03:46 UTC#1
Will My N1 play video Ipod if i connect it through the external video component??
you know there in the brain unit, there is a external video omponenet where i can connect composite cables..
Thank you
Posted Nov 12, 2008 · 04:44 UTC#2
Yes
Posted Nov 12, 2008 · 05:09 UTC#3
Oh Thank you Will it play while i drive?
and i want to connect rear view camera, will it still work (do i connect the camera different port)?
Thank you!
Posted Nov 12, 2008 · 05:11 UTC#4
If you bypass it, it will work while in motion. If you don't, it won't
The ipod should go to the AV input. The back-up camera goes to the back-up camera input. They are completely independent of eachother
Posted Nov 12, 2008 · 05:35 UTC#5
Thank you very much!
I should ask audio shop for bypass.
Or if i have default 40mt version then do i still have to bypass it?
Thank you again!
Posted Nov 12, 2008 · 15:36 UTC#6
Thank you again!
just ground the parking brake wire and its bypassed
