my avic-d1 is already installed (had a store do it for me), but now i've got the xm receiver and want to hook it up. however, the instrucitons that came with it were somewhat confusing. the ports on the back of the xm receiver are:
antenna, ip-bus out, data out, ip-bus in, power supply
1. which one of these do i plug into the back of the avic-d1? just the "data out" cable? i'm not sure what the deal is with the "ip bus out" and "ip bus in" ports.
2. i see that i have to power the xm unit and it has a power supply port. the included cable has a yellow (battery), black (ground), and red (acc) cable. i assume that i just splice into a yellow battery cable for that, black ground cable for that? should i look for any special yellow or black cables to splice into?
however, the red cable says "Do not use this lead when the product is connected with an IP-BUS cable. If both an IP-BUS cable and this lead are used together, the product may not work properly. (Fold this led away and keep it unused until you need to turn the product ON/OFF independently from other connected devices).
i guess if i knew the answer to #1, i would know what to make of #2.
help! ![]()
