linear compass
By johnnykim · Nov 13, 2008in Hacks/Mods💬 8 posts👁️ 2,151 views
Posted Nov 13, 2008 · 05:40 UTC#1
i did a search and couldnt find anything for linear compass. i did see someone have it and also notice that the image is there in the ui_pioneer\800_480.
ill prob play around with the navigatemap_800_480.ui when i get a chance.
but till then, anyone know the hack for it?
thanks in advance.
ps. still new to this! haha
Posted Nov 13, 2008 · 14:54 UTC#2
this is the code you need to look for/add in navigatemap_800_480.ui
you of course need to set the x and y, height and width, and z to what you would like and change the file name to what ever you are using.
Posted Nov 13, 2008 · 15:56 UTC#3
Was interested in adding this myself. Won't we need those bmp files as well though?
Also, does this change just the 3D compass, or the 2D compass as well?
Posted Nov 13, 2008 · 16:21 UTC#4
this is the code I use
;compass
with the attached .bmps
linear_compass.zip
Posted Nov 14, 2008 · 13:17 UTC#5
thanks! ill give this a shot later today.
Posted Nov 15, 2008 · 19:50 UTC#6
Also, be sure to comment out the old compass code so they don't render that image over this hack as well.
Posted Nov 22, 2008 · 18:22 UTC#7
Trying to get this to work with the Stop nav code.. anyone using this one with it?
Posted Nov 29, 2008 · 02:44 UTC#8
Ok, I can't seem to figure this one out on my own. Maybe I'm too reliant on JavaDocs :)
Does this code just change the image or does it change the style from the map style compass to the aviation style one? If the latter, where do I drop those three lines of code on top of? Thanks!
