Only Green Boxes when booting into WinCE Mode
By csalinas · Nov 14, 2008in Hacks/Mods💬 3 posts👁️ 914 views
Posted Nov 14, 2008 · 05:13 UTC#1
I'm trying to do the Software hack by modifiying the Pioneer.ini file.
I have downloaded the Testmode Zip file and extraced both folders to the root of the memory card and booted up the Radio. I get the splash screen then i get the Copy window that copies the file. After that when ever I try and close the copy screen things start to highlight green and the Windows Start Button and Bar goes away and turns green. I have upgraded to 2.0 .
Please anyone help me.
Chris
Dallas
Posted Nov 14, 2008 · 05:17 UTC#2
so when you close out "x" of the copy screen, your taskbar disappears? try moving cursor down by taskbar and clicking... also top left hand corner it says "my device" you can double click that and go into windows explorer
Posted Nov 14, 2008 · 07:39 UTC#3
Well after tapping the X on the upper right hand part of the screen about 50 times it finally cleared up and i was able to use Windows CE and apply the hack. And yes it did work (the hack). I guess what the problem is, because the screen is small you have to hit the X just right and i was using my finger next time i'll be sure to use a stylus. Also after i was in windows CE i went into control panel and recalibrated the touch and that helped out when applying the hack ALOT!!.
