Installed the Bypass for Video and now my Bluetooth not work
By Wilkinda1965 · Nov 15, 2008in Problems/Troubleshooting💬 8 posts👁️ 1,119 views
Posted Nov 15, 2008 · 00:19 UTC#1
i installed the bypass per the stick on this website. now when i try to make a call or receive a call my bluetooth is in permanent "Mute" mode. Anyone else have this issue as well????
Posted Nov 15, 2008 · 00:32 UTC#2
Did you move the mute wire to the right hole?
Posted Nov 15, 2008 · 13:33 UTC#3
Yes, all works except the blue-tooth function now :cry:
Posted Nov 15, 2008 · 22:54 UTC#4
pulled everything apart and put back together..nuthin....pulled back apart and hit the reset on the BT adapter and now it all works
Posted Nov 20, 2008 · 17:29 UTC#5
Bought a used D3 off ebay and everything is working fine. I am having this issue also. Pretty sure the wire is flipped. Thought I reset the bluetooth unit and powered on/off a few times.
I can make calls through the headunit and they can hear me through the mic but i cant hear them through the speakers. When someone calls me it rings through the speakers and I can hear that.
Posted Dec 01, 2008 · 03:58 UTC#6
so is it the bypass????? i have the same problem, no sound, they hear me but i cant hear anything? plase help I did the by pass can that be the problem?
Posted Dec 01, 2008 · 07:13 UTC#7
You plugged the p-bus cable in the wrong hole on the bluetooth box. Put it in the other one
Posted Dec 01, 2008 · 16:14 UTC#8
It only fits in one hole, the purple one, the other one is for the multy disc player something like that. The D3 connects to my cell phone but there is no sound from my speakers?
