Multiple camera input????? HELP HELP
By ASMITH1123 · Nov 15, 2008in Hacks/Mods💬 4 posts👁️ 1,651 views
Posted Nov 15, 2008 · 00:49 UTC#1
I have a customer with a rv with currently 3 cameras a rev. a left and a right, all of which activate through their repective signal..... however the customer wants to ugrade to the f90 and i am stuck trying to figure out a switching system to incorp. his cameras which still work, however his montior doesnt ..... any help will be greatly appreciated
Posted Nov 15, 2008 · 13:31 UTC#3
That will work but it is not necessary.
Use a a three position dial or toggle switch, RCA Y connectors, and three relays. Join all three cameras into a single input on the head unit. Then wire the switch to the relays so that each camera only has power when it is selected on the switch. I have done this on at least a dozen times and it works perfectly.
Posted Dec 16, 2008 · 09:10 UTC#4
A little late with my reply, but I just stumbled across this item:
http://www.vidswitch.com/
This will let you use the F90s rearview camera input with his existing cameras.
A bit pricey, but RV owners tend to have deep pockets... :wink:
-Eric
