how to reinstall the update
By haniakrim · Nov 16, 2008in Hacks/Mods💬 18 posts👁️ 4,972 views
Posted Nov 16, 2008 · 12:08 UTC#1
0- copy the files of update that you download it in your storag card (LPUE080)
1- go to test mode
2- take a packup of ( copy of My Flash Disk)
3- delete all files in My Flash Disk
4- run the file update.exe witch is this ( \My Flash Disk\APL)
5- then the device will reboot after update
6- go to test mode
7- copy back the igo folder to your device witch in this (\My Flash Disk\APL2)
8- reboot your device
thank you for every one i hop that is good and can help
:lol::lol::lol::lol::lol::lol::lol:
Posted Dec 03, 2008 · 02:39 UTC#2
has anyone try this??
i would like to re update my unit?
Posted Dec 06, 2008 · 23:42 UTC#3
This Works Just deleted my flash drive via using Testmode. Then opened my storage card where i already had the LPUE080 and TTS on.
Went to LPUE080/APL/UPDATE aplication<-hit run
Then it goes through normal update process.
Posted Dec 12, 2008 · 05:30 UTC#4
I just bricked my unit last night, and this fixed everything!!! Thanks again!!! :D
Posted Dec 12, 2008 · 21:34 UTC#5
What would happend if i do all that with EU firmware 1.9 on US unit???
Posted Dec 12, 2008 · 23:49 UTC#6
Just an update the first time i did it, it actually did not work. Thank god i did a backup of "my flash drive" before i did most of my mods. Reinstalled it and my unit came back but still had some mods that were slowing it down. SO i decided to try this one more time.
Things you need:
2gb SD card
Laptop/PC
Steps:
1.)copy the Igo folder on your actual Avic unit MyFlash/APL2
2.)Move this folder onto you computer. (You will need the space)
3.)Put the testmode and Metacap folders on SD
4.)Also put the LPUE080
5.)Put the card with the above files in your Avic and start it up.
6.)Go back to the My flash Drive and (DELETE ALL FILES)even after selecting all and deleting,two popped up on me but i went back re-selected these and deleted them
7.)navigate back to the Storage Card
8.)Open the LPUE080 folder
9.)go to LPUE080/APL/find the application that say "UPDATE"
10.)double click or hit run
11.)goes through the regular update process(takes like 10 mins)
12.)Unit restarts and is still in testmode
13.)Remove SD (but make sure your car is still running and in testmode)
14.)Put SD card in computer and delete ALL FILES
15.)now copy back the Igo file which you moved to your computer in step 1
16.)now put your sd card in your avic(which is still running and in testmode)
17.)go to storage card
18.)select the Igo file and cut it
19.) No go back and open My Flash/APL2 and select the old iGo file and delete it.
20.)Now copy and paste the iGo file which you cut from your storage card and paste it in the APL2 folder
21.)Close out of windows and shut off car
22.)remove SD
23.)start back up and finish the TTS part of the upgrade.
!!!!!!!!!YOU'RE DONE!!!!!!!!!!!!
Posted Dec 13, 2008 · 18:08 UTC#7
Posted Dec 13, 2008 · 18:30 UTC#8
Dont know im sure if you have a back-up of your originial iGO file before your mods, it should go the same. I havent kept up with EU upgrade but if there is on and you have those files. Give it a whirl!
Posted Dec 13, 2008 · 20:04 UTC#9
Thank you for the info :)
Posted Jan 02, 2009 · 22:09 UTC#10
I've asked this elsewhere but never received a response:
Why do you need to load the original iGo folder back on after the update?
I know my problem is stemming from that folder, wouldn't I just be reloading the problem on there if I put it back?
Thanks.
Posted Jan 02, 2009 · 22:47 UTC#11
Thanks.
The new files that come in the update dont have the full igo file which will make your Avic unit work. This is why it was stressed and very important that yo copied your actuall igo file before you sart mods.
Posted Jan 02, 2009 · 23:21 UTC#12
sounds good, I am going to give it a shot......I am having the ezrider.exe problem, hopefully it works if I overwrite the existing corrupt ezrider file and put my original back on there.
Posted Jan 07, 2009 · 15:54 UTC#13
I seem to have lost my button sounds after following the instructions above. Not a big deal really. They are loud and annoying. Just makes you wonder if something else is missing.
I thought it fixed my rebooting problem but no go.
Posted Jan 13, 2009 · 23:19 UTC#14
i suspect my igo folder may be the source of some of my issues, that being the case, is there anywhere to acquire a complete copy of the igo folder i so desperately need? going to try backing up what i have and see if it works. but, assuming that doesn't help, do i have any options short of calling up buddy and stealing his unmolested igo folder from his identical deck (problem is he lives 4 hrs away)
Posted Jan 14, 2009 · 04:02 UTC#15
oooh man. i got this poor f90bt in rooough shape. tried to do this re update dealy. annnd no dice. tries to restart when i restart from wince and doesn't do anything. *but* i can press the menu button, and i can access my music, but no video or nav. gives me the nav screen warning and that's it
ok button doesn't respond.
Posted Jan 15, 2009 · 20:12 UTC#16
this procedure restore also bt software???... my unit lost it and i can't update it in normal way
Posted Mar 02, 2009 · 16:56 UTC#17
When I did this, I also lost most of my button sounds. I was able to restore them by copying the DATA directory off of my wife's F900. I'm surprised no one else has said anything about this, but if anyone reads this, you may want to back it up as well as your iGo directory. Thanks for the how to.
Posted Mar 03, 2009 · 00:54 UTC#18
I did the update reinstall and my ipod still wont show up. Any ideas? Its like the usb is dead. PLEASE HELP! its a 6g 80gb ipod classic. I have two 6gen ipods and neither work my flashdrive wont show up either.
