Can some one explain what am I doing wrong? I downloaded the firmware, put it on a sd card and followed the instructions and I'm having no luck. Is there something I'm skipping? It seems as though the unit won't read the card. I don't know.
Try to do up date on F90
I had trouble doing mine too. Do you have anything extra hooked up? I had to unplug the ip bus for the sirius and then the update worked fine
No I don't have anything extra except the ipod cable. That's all I have.
Did you uncompress everything and put it in the card properly?
You don't put the Firmware folder onto the SD, you put the 2 folders within the Firmware folder onto the SD.
Also make sure nothing is plugged into your usb
Please be a little more vague about the problem you're having
Ok i've done that and still nothing. Is there anything else insides those folders that needs to be extracted. I've been trying to do this update forever and I don't know what hell is going. Is there an step by step or better yet with pictures because i'm sure there are a lot of people who are not computer savy that will get lost. I'm very computer literate but is there something i'm missing? Nothing is plug into the usb, put just the two folders on the card and it still won't read. It has got to be a step that i'm missing. Any help would be gladly appreciated.
