Car speed signal input on 2005 Matrix
By avic4u · Nov 17, 2008in General💬 3 posts👁️ 1,343 views
Posted Nov 17, 2008 · 06:25 UTC#1
I'm hoping I can get a quick answer to this question as I'm looking to try and make my installation happen tomorrow.
I am installing the F90BT head unit. I have done a lot of investigation and homework as far as wiring etc. - but in looking over the harnesses and wiring I have here, only the "car speed signal" wire confuses me.
This is the pink wire and I must connect it to the Vehicle Injection computer. Is there another name for this computer? I can't seen to be able to locate it on my 2005 Toyota Matrix.
Also, I prefer to mount the GPS antenna on the dash. Are you guys getting a good strong signal?
Thanks,
Marc
Posted Nov 17, 2008 · 13:26 UTC#2
Thanks,
Marc
Look for whats called a VSS wire. See the following link:
http://www.tundrasolutions.com/forums/c ... -vss-wire/
It may or may not help, just try to locate a wire with the same characterlistics (Violet/White) even if its in a different spot.
Also, you can put your GPS antenna on the dash, but be prepared for your altitude to be off by a few feet. This is my personal experience, others may disagree.
Posted Nov 18, 2008 · 00:20 UTC#3
VSS = White/Green at Instrument Cluster, Pin 18 (AC)
