Hello.. I have an Avic-N2 that i recently tried to upgrade to the 70MTP Discs. The upgrade went smooth, but now i am unable to input any address in the GPS, it is simply grayed out. The parking brake is grounded and the unit was not initially bypassed. I went ahead and bypassed the unit thinking this will correct the problem, but it still doesn't let me enter an address at all(whether parked or driving). I am able to drive and watch a DVD now but i still cannot input an address. I also noticed the initial installer didn't hook up the VSS wire, so i went ahead and did but that also didn't enable the address search. Any help to solve this problem would greatly be appreciated. Thanks
N2 Upgrade Problem
Bad burn
I am going to try and burn the latest ones 80MTP then. WHat is wierd is it updated completely fine, now it doesn't want to enable the navigation features. Have you seen this before that you are suggesting bad burn? Thanks for the quick response
Yes
I went ahead and downloaded the 80MTP map, burned, and verified. Everything works fine now! Thanks for all your help CamelTowing.
question, if i'm in memory navi mode does the button still stay grayed out. I know if i put the disk in it works but if i take the disc out it won't let me set a new route or anything else
You need the nav disc in to set a new route or other things.
hi i justdownload the upgrade from CNDV-60M to CNDV80MT but when i insert the disc into the unit shows a message that says "wrong disc, please insert the rigth one" or something like that. anyone know whats the problem? please i need some help, thanx
