Speed Pulse Wire question (New F-150)
By mikebaby · May 06, 2006in General💬 8 posts👁️ 1,953 views
Posted May 06, 2006 · 15:42 UTC#1
I am 99.9% I have the speed pulse wire hooked up properly however the nav system is always a few MPH off from my trucks spedo. Also Has anyone ever seen the AVIC monitor the speedpulse at a rating higher than 0?
Thanks,
mikebaby
Posted May 06, 2006 · 16:43 UTC#2
Fords are notorious for having their speedos read a bit on the "Faster" side.
~WW
Posted May 06, 2006 · 18:41 UTC#3
if it says 0 when moving you dont have it hooked up correctly...
Posted May 06, 2006 · 22:17 UTC#4
I have it wired to the grey/black wire.
mikebaby
Posted May 06, 2006 · 22:44 UTC#5
I think thats what color the speed wire was on my ford, you sure u have it connected well, those splicers can be a bitch to get right.
Posted May 07, 2006 · 10:21 UTC#6
I'm pretty sure. I guess when I try to install my PAC stering wheel adapter I can verify. THat won't be for a couple of weeks though.
mikebaby
Posted May 07, 2006 · 10:22 UTC#7
I have never been on a website that will let you post without logging in first.
mikebaby
Posted May 08, 2006 · 18:33 UTC#8
2003 VSS Wire: LOCATION 12- POSITION 68 OF 104 PIN CONNECTOR OF PCM
VSS Wire Color: GRAY/BLACK
VSS Pulse: 8000
VSS Tach Wire: LOCATION 12- POSITION 78 OF 104 PIN CONNECTOR OF PC
