Copy screen locking up?
By jayrunquist · Nov 18, 2008in Hacks/Mods💬 5 posts👁️ 1,336 views
Posted Nov 18, 2008 · 04:20 UTC#1
I copied the files to a formatted (FAT32) SD card and stuck it in my F90BT only to see the copy screen pop up, the progress bar complete, the pop-up to go away .... and be replaced by a green box. I couldn't click the X in the upper, right-hand corner either. It's like the unit won't run any apps or something. I was able to get to the START button once and then click on Explorer but then everything went green.
Anyone???
(BRAND new F90BT with 2.0)
Posted Nov 19, 2008 · 02:17 UTC#2
i had the same problem. hope you get an answer.
Posted Nov 19, 2008 · 02:59 UTC#3
I had this issue, too. However, if I jus waited (about 3 minutes), mine finally became responsive. Once I could use it, it was quite slow. Like running Windows Vista on a 486 with 16mb RAM. :-)
I'm not saying that just waiting will work for you, but that was my experience.
Posted Nov 19, 2008 · 05:16 UTC#4
With the stylus, tap and hold on the top bar of the window and drag it to the middle of the screen. Then you should be able to hit the "X". Good luck
Posted Nov 20, 2008 · 18:02 UTC#5
Had the same problem when I first got my 900. The solution that i used and has work every since is wait til you see the clock on the bottom of the right hand part of the screen change from 12:00 to the real time. Thats when you know that the system has finished all or most of the boot stuff Then with the stylus tap the X on the top right. I might have to tap it a couple of time to click on it just right. Once your in Windows goto the control panel and re calibrate the touch screen. This will help out ALOT when your playing around in Windows CE
Chris
Dallas
