Z2 = No sound on Sirius
By Brewdude · Nov 18, 2008in Problems/Troubleshooting💬 7 posts👁️ 966 views
Posted Nov 18, 2008 · 18:08 UTC#1
Hey guys,
Here's what I have:
2007 Ford F150
Stock audiophile system. ( all speakers and subwoofer are stock )
Schoshe wiring harnesses
I just installed a brand new Z2 and have no sound when on Sirius. I can change the channels and see the channel names, but no audio at all. The DVD/CD player works fine and the NAV is working fine as well. I do not have the FM antenna hooked up yet since I need some adapter 'cause Ford uses some weird end on the ant. wire. But I don't think this should cause a problem with the Sirius.
One other question. I have the wire harness for the truck and the factory sub. The sub harness has 2 blue wires on it. Do they have to be hooked up to anything?
Thanks!!
Posted Nov 19, 2008 · 00:10 UTC#2
ehh, nevermind. It was a bad cable. It's all fixed and working good now.
Posted Nov 19, 2008 · 18:13 UTC#3
However, I would still like to know about the 2 blue wires on my sub woofer adapter harness...
Anyone???
Posted Nov 21, 2008 · 13:45 UTC#4
Nobody? Really :?::roll:
Posted Nov 21, 2008 · 14:13 UTC#5
What vehicle wire color does the blue wires on the adapter connect to? Dk Green/Purple?
What does the instructions with your Schoshe adapter say? What is the model number of your adapter? Give me something to work with here :)
Posted Nov 21, 2008 · 14:45 UTC#6
I don't have instructions for the harness. There was some stuff written on the back of the plastic bag it came in, but it was messed up and I couldnt red it.
Right now, the 2 blue wires are not connected to anything since I have no idea where they go. I'm assuming they are the amp turn on wires??
Here's a link to the adapters I have
http://www.crutchfield.com/p_120705521/ ... ml?tp=2977
Posted Jan 02, 2009 · 04:50 UTC#7
those 2 blue wires turn on the factory amplifier for your factory sub.
there are also 2 RCA's that come with that plug.. 1 of the RCA's is for the sub, the other is for interrior amp (if applicable)
you may have to install a 1k ohm resistor on the Blue turn on wire to eliminate turn on pop. some need it some dont.
also the problem with your siruis wasnt a bad it cable it was a bad installation. you someone plugged the cable into the input port on the sirisu mod.
there is a blu and a black plug on Pioneer SAT units.
the BLACK is the output and goes towards the radio, the BLUE is an INPUT for a 2nd mod in the chain (ipod adapt, blutooth, XM, Aux input)
if you plug into the wrong port you will get all data and controls but no audio.
Happy installin
Wolfz23
