VSS wire location on 2000 Honda Accord?
By humblehyper · Nov 19, 2008in General💬 9 posts👁️ 2,835 views
Posted Nov 19, 2008 · 05:21 UTC#1
VSS wire location on 2000 Honda Accord LX 4dr 4 cyl sedan. Anyone knows where it is? I'm going to try and install an Avic F90BT myself, I pretty much know how to connect the wires except for the VSS, since I'm bypassing the mute wire, I don't need to connect the parking brake wire right? Thanks much guys!
Posted Nov 19, 2008 · 06:06 UTC#2
I had a honda Accord and the manual was helpful or check some of the online honda forums.
Posted Nov 20, 2008 · 19:25 UTC#3
You need to ground the parking brake wire AND move/ground the mute wire if you are doing the bypass. If not, connect them as intended.
As for the VSS wire, this is all I could find:
http://www.the12volt.com/installbay/cruisedetail/1040.html
Hope that helps.
Posted Nov 20, 2008 · 23:54 UTC#4
Blue/White 31 pin connector on ECM.
Should be under/behind center console accessible at the passenger side.
Hope this helps.
Posted Nov 21, 2008 · 03:26 UTC#5
Thanks all so much for your help. One more question, if I'm doing the bypass mute wire thing do I still need to hookup the parking brake wire? Or not anymore?
Thanks again.
Posted Nov 21, 2008 · 04:31 UTC#7
Now I understand. This is my first time installing a stereo LOL, thanks much!
Posted Nov 22, 2008 · 07:52 UTC#8
Hope this helps.
What does the ECM look like? LOL sorry for being so ignorant :(
Posted Nov 22, 2008 · 17:45 UTC#9
In most cases it is a silver box. Sometimes it may also say ECM or Electronics Control Module on it somewhere.
Beware of any airbag harness or mudule. They should be well labeled, and will typically have bright yellow wire loom, or harnesses.
