Removed Mute wire from harness
By DL771 · Nov 20, 2008in General💬 3 posts👁️ 847 views
Posted Nov 20, 2008 · 18:59 UTC#1
All,
I removed my Mute wire from the Pioneer harness in hopes to perform the hard wire hack. Well, long story short, I ended up breaking the metal end of the tip of the Mute wire. So now, the mute wire is no longer on the harness.
Since I don't have any equipment that facilitates the Mute wire, is it safe to assume that running without the wire in the harness is okay?
Thanks.
Posted Nov 20, 2008 · 19:16 UTC#2
The unit will function as intended without the mute wire in place, but you will lose all the benefits of the bypass.
*edit*
I have not tried it myself, but this might be a good excuse for you to attempt the software bypass
Posted Nov 20, 2008 · 19:24 UTC#3
Yeah, thanks to the instructions on this site, I'm well aware of the software bypass. Otherwise, I'd be outta luck :(:(
But okay, thanks for confirming that for me!
