90BT is coming.
Question: does the F series have the same wiring harness as the D-3? Was hoping to plug and play my swap from a D-3 to this new unit to shave time on install.
thanks
90BT is coming.
thanks
Yes. If you plan on bypassing though, you have to move a pin in the RCA harness
I should have mentioned my D-3 was already bypassed...the F series needs to be moved to a different pin location (in the harness)?
CamelTowing Posted: Fri Nov 21, 2008 12:42 am Post subject:
Done; thanks for the clarification Camel.
