Dimmer wire for HU, interferes with subwoofer?
By toofast4yourazz · Nov 21, 2008in General💬 7 posts👁️ 997 views
Posted Nov 21, 2008 · 18:57 UTC#1
Can the Dimmer wire for the avic-d3, interferes with the subwoofer?
because I get a loud amplified humming noise when i turn my headlights on with my amp and sub hooked up..
since the dimmer switch is activated when u turn headlights on, i was thinking it could be that.. any ideas?
BTW, even when i unplug the amp, i still get a semi low and quiet humming noise from the side stock speakers..
:shock:
Posted Nov 21, 2008 · 23:00 UTC#2
you might have an amp wiring issue. either bad rcas'. or a grounding issue. or you ran your power and rca's down the same side of the car. do you have h.i.d. headlights?
Posted Nov 24, 2008 · 01:47 UTC#3
why would hids affect it in any way? just wondering because hids do draw less current then the stock 55watts bulbs....hids draw 35watts
Posted Nov 24, 2008 · 11:12 UTC#4
ive seen hid's cause some odd problems in audio systems before. just a thought. saw a few that actually cut the radio reception when the headlights were turned on. dont know if they were poorly wired, or just crappy hid's. i didnt put them in
Posted Nov 24, 2008 · 14:48 UTC#5
If you do have hid's check their ground. They do use "only" 35 watts, but it is at a much higher voltage and that higher voltage can put out different frequency interference. The ballasts are step-up transformers and that could be the source of your noise.
ct_mike
Posted Nov 24, 2008 · 16:51 UTC#6
ok i fixed it, i took out the head unit, and found the culprit, a positive wire lost its cover and was exposed touching the dimmer wire, which was causing the noise.
thanks for the help
8)
Posted Nov 24, 2008 · 17:17 UTC#7
thanks for the help
8)
So the dimmer wire was exposed too?
