IceColdEuro said:
Good afternoon!
After reading tons of posts, both here and at VWV, AND after having received my AVIC-D1, I am about ready to install the whole shebang into my 2003 Jetta. But first I want to double check a few things, so if you could just say "Yup" or "Hell No!" I'd greatly appreciate it.
1.) For the bypass I took the cell mute wire out of the plug and inserted it into the empty corner sport. I then connected the other end of that wire with the parking break and reverse wires from the pioneer plug and conected the three of them with the black ground wire that came from my 70-9003 harness that's connected to the existing harness in my Jetta. Is this correct as far as the bypass goes?
Yup
IceColdEuro said:
2.) I connected the yellow 12v constant (memory) wire from the pioneer plug to the yellow wire coming from the 70-9003. The instructions from the 70-9003 say that this is the 12v memory wire. The original stock radio says labels that pin as KI.30. Is this correct?
Yup
IceColdEuro said:
3.) Should I run the red wire from the pioneer plug (switched power) to #31 in the fuse box, the actual connector with the yellow/black wire near the OBDII, or the red/brown keysense wire near the ignition? (There is no switched power in the harness for that year/model VW.)
run it to the red/brown key sense wire. This way the avic will work more like the stock radio. It'll stay on until the key is removed.
IceColdEuro said:
4.) The pioneer plug has two ground wires coming out of it that join together (came that way). Should I run those to the same black ground wire from the 70-9003 to which I connected the parking brake, reverse, and "cell mute" wire? Or should I run it somewhere entirely different?
Hell no. Ground em all to the black wire in the 9003 harness. The reverse wire should not be grounded. If you're not going to hook it yup then just tape it up.
IceColdEuro said:
That about covers it with the possible exception that I have no idea where to connect the orange/white dimmer wire as the stock harness doesn't supply that. I don't really care about that too much though.
You could tap that into the parking light wire if you want the map to switch over to night mode when you turn on the headlights. If you don't care about that then just tape it up.
IceColdEuro said:
Thank you all!
You're welcome.
