No rear dvd after Z3 upgrade
By wechtech · Nov 23, 2008in Problems/Troubleshooting💬 9 posts👁️ 1,270 views
Posted Nov 23, 2008 · 00:32 UTC#1
After Z3 upgrade, I no longer have rear dvd on the headsets. Any help would be greatful. I tried aux of and on. The rear view is set to DVD.
Thanks as always guys.
Posted Nov 23, 2008 · 18:19 UTC#2
Double check your settings, there has to be something that is missed...
Posted Nov 25, 2008 · 21:47 UTC#3
i've got the exact same problem, when the rear screens are on mirror setting, everything but the DVD shows up on the rear screens, i went through all the settings and they were exactly the same as on my Z2 and the rear screens worked with DVD, now they don't on the Z3... tried resetting the unit, didnt do anything
Posted Nov 25, 2008 · 21:54 UTC#4
i just realized this, would it have something to do with the bypass? i mean the video still works on the front screen, but maybe the unit doesnt realize that the rear screens are bypasssed as well and blocks out the dvd signal...
Posted Nov 26, 2008 · 00:06 UTC#5
Nope it has nothing to do with the bypass. The bypass just makes the unit see the parking break as being "on", even when it isn't, so your rear screens should work as well.
Posted Nov 26, 2008 · 06:55 UTC#6
x2. Neither the bypass, nor the upgrade would cause that. Like Bur said, double check your settings since they were reset when you upgraded.
Posted Nov 27, 2008 · 00:41 UTC#7
i looked through all the settings a million times and havent found anything related to the rear screens other than the button in the av selection menu which selects mirror or dvd for the rear screens... the screens worked fine on my z2, but as soon as i upgraded it to a z3, dvd's dont show up on the rear screens... and since im not the only one having this issue, i dont think its the hardware....
Posted Jan 21, 2009 · 21:51 UTC#8
anyone else experience this issue or find a solution?
Posted Feb 24, 2009 · 19:05 UTC#9
so anyone figure this out or is my unit screwed up?
