GPS status
By humblehyper · Nov 23, 2008in General💬 5 posts👁️ 996 views
Posted Nov 23, 2008 · 04:55 UTC#1
When the GPS status say's "Accuracy - High", does that mean I'm getting a good signal? Also there are times that it's saying I'm "0 feet" from my exit or turn even though I'm still about 20 or 30 feet away from it. Is this normal? Or do I need to relocate or check my vss wiring?
I took a shot of the GPS status (sorry cellphone camera only), it shows the signal bar on each satellite.
Thanks much!
Posted Nov 23, 2008 · 05:01 UTC#2
high means good accuracy to where you are/ speed your going
Posted Nov 23, 2008 · 05:04 UTC#3
I think it will show High if you have signal from 4+ sats (enough to determine position _and_ altitude) and signal is strong enough to ha ve rather small positioning error (I'm not sure at what point they actually use High as opposed to not).
20-30 feet is reasonable. GPS will give you 5-10 feet error easily, and maps aren't perfect either...
Posted Nov 23, 2008 · 06:01 UTC#4
OK thanks guys, I guess I did connected it right LOL
Posted Nov 23, 2008 · 18:23 UTC#5
wow you got it installed allready,
I got to get of my ass and get going on mine. :oops:
