Does anyone else find that when they set the random on USB/SD its gone the next time you turn on the vehicle?
Is there a switch that can be turned on in one of the UIs?
check to see if you have your constant 12v wire hooked up.
apparently it turns off when you swap cards or usb dirves... ? It was working fine today but I didnt change any media so that must be it.
Thanks.
I've had the same issue without swapping cards or drives.
Are your soundsettings as you have stored them?
My F90BT tends to intermittently switch off random play from SD/USB. It also "forgets" what track it was playing on SD/USB, starting over at the first track it finds on either storage device, and the clock reverts to 12:00 until it's auto-corrected by GPS within a few minutes of startup. All of these things happen after the vehicle has been shut off for roughly 2 hours or more, However, the AM/FM/XM presets, EQ, fader, etc. are not affected when this happens. I'm on my second F90BT, as the first one had an MSN Direct problem for which I had it exchanged. Both units had 2.0 firmware, and exhibit the 3 problems shown above.
