How to Connect Ipod touch
By guod · Nov 25, 2008in Problems/Troubleshooting💬 9 posts👁️ 1,285 views
Posted Nov 25, 2008 · 01:20 UTC#1
I have an ipod touch with firmware 2.1 on it and I cannot get the ipod to show up. I have an ipod composite cable hooked up to the av input on the back of the unite and have the usb cord conned to the usb input. then i plug my ipod in and all it does it charge and makes a weird noise when I connect it. Am I doing something wrong? I also changed av1 input to ipod.
Posted Nov 25, 2008 · 01:56 UTC#2
go to av settings and change av1 to ipod
Posted Nov 25, 2008 · 01:58 UTC#3
i said that it is on av1 ipod
Posted Nov 25, 2008 · 02:02 UTC#4
Did you upgrade the deck to firmware 2.0?
Posted Nov 25, 2008 · 02:27 UTC#5
yea
Posted Nov 26, 2008 · 06:18 UTC#6
bump......
Posted Nov 26, 2008 · 06:49 UTC#7
Does the screen on the iTouch say "Pioneer OK to disconnect"? Because if not then it could just be your cable. If you have access to another ipod, try that first.
Posted Nov 26, 2008 · 16:14 UTC#8
no it just shows that it is charging as if i were using a regular ipod usb cable
Posted Nov 26, 2008 · 22:35 UTC#9
You might try resetting the ipod. Seems to work for some on here
