D2 fit into 06 escape ?
By jhoglesr · Nov 26, 2008in General💬 7 posts👁️ 954 views
Posted Nov 26, 2008 · 13:33 UTC#1
Crutchfield says the D2 doesn't fit in 06 Escape . They also said it wouldn't fit in my Century but it does . Does anyone know for sure ?
Posted Nov 26, 2008 · 14:53 UTC#3
I don't believe there is a kit for it but it will fit. You will need to modify the the opening a bit and use some sort of brackets to hold it in. Use the black trim piece that comes with the unit to hide everything.
Posted Nov 26, 2008 · 14:58 UTC#4
Crutchfield also said a D2 wouldn't fit in my 2003 Ford SuperCrew, but it did. I had Best Buy install that stereo and warned them that Crutchfield said it wouldn't work but it was compatible by their computers and again, it worked.
Posted Nov 26, 2008 · 22:28 UTC#5
It will fit. You will have to file down a little bit of the plastic. Then just use your own screws in those 8 little holes on the D2 and screw it into the plastic trim
Posted Nov 27, 2008 · 14:33 UTC#6
Thanks for your help guys . I'm still not sure if I'm going to buy the Escape , but I know that I'm not giving up my in dash xm & nav . :)
Posted Nov 27, 2008 · 15:38 UTC#7
LOL, that's how I was car shopping back in March, If it didn't have a double-din opening or a dash kit, I wasn't interested.
