F900 Resets on map / destination input..
By lowbug · Nov 26, 2008in General💬 4 posts👁️ 705 views
Posted Nov 26, 2008 · 20:57 UTC#1
Hi, I was recently in Birmingham (UK) and every time I put in the destination the unit reset. I tried several times ( i tell you i nearly smacked the screen out the dash! :D ) If i put in the ICC under POI it found it and took me there.. I've never had this before? I'm sure I saw about a firmware update either here or on the Pioneer website to fix this biut i've searched and can't find anything and the Pioneer website only has the 1.9 firmware... ARRGHHH!! :D
Posted Nov 26, 2008 · 20:58 UTC#2
I forgot to say , the next day i tried and it did the same, I tried another place and it worked, and then tried another destination and it reset... :s
Posted Nov 27, 2008 · 20:59 UTC#3
anyone else had this issue? :D
Posted Nov 28, 2008 · 02:21 UTC#4
Sound like your unit is having some issues reading from memory causing a restart.
Try doing a reset, via the menu under navigation reset to defaults, reset using the button next to eject and reloading the default language again.
Also try putting in a new address, if those all result in the same issue, I would say its time for service.
