I have a z2 that I want to test before i tear my dash apart for install,
is it possible to use a battery charger to power up the z2 while i test it?
In other words, hook up the acc and constant power wires to the + and the ground wire to the - of the battery charger, then set the charger on the lowest setting, turn on the z2 so I can test it and make sure it's all working ok.
