Quick question
By gtogsx · Nov 28, 2008in General💬 10 posts👁️ 1,159 views
Posted Nov 28, 2008 · 03:54 UTC#1
Which one do I need?
Posted Nov 28, 2008 · 03:59 UTC#2
what car are you installing in?
Posted Nov 28, 2008 · 04:29 UTC#3
Oops. Forgot to say what which car.
This is for my 08 Scion tC
Posted Nov 28, 2008 · 06:04 UTC#4
Crutchfield.com shows number 1.
Posted Nov 28, 2008 · 07:28 UTC#5
Yeah that's what I was looking @. Someone else in the forums said number 2 but I think it's number 1. Will be ordering it now.
Posted Nov 28, 2008 · 07:32 UTC#6
they usually know their stuff
Posted Nov 28, 2008 · 17:37 UTC#7
Cruchfield said my f90 will not fit in a 02 qx4. They dont know everything.
Posted Nov 29, 2008 · 10:12 UTC#8
you can make any head unit fit any car. Crutchfield says it fits based on the stock setup. Crutchfield also told me I couldn't put a DD in my 02 Silverado psssh little fiberglass never hurt no one lol.
Posted Nov 29, 2008 · 10:38 UTC#9
They also said my F90BT wouldn't fit in my HHR SS. But after a little work with a Dremel it fit fine. But they did say it would fit in a Scion. And if Crutchfield says something will fit it usually does. That's what I based my statement on.
Posted Nov 29, 2008 · 10:41 UTC#10
X2. If you want to truly know if it will fit, check out www.metraonline.com, and check for a dash kit. If they don't have one, google _your vehicle_ double din, and see if it has been done before. Then you'll truly know if it is possible or not.
Don't follow Crutchfield like a bible, as they may not always be 100% correct. My RX-8 has 8" woofers in the doors, and Crutchfield said 6.5" components WOULD NOT fit because they weren't the factory size. But anyone with a brain knows that you can fit 6.5" components in an 8" opening.
